Configure the counter sampling interval values at port level to determine how often the sFlow agent polls and exports counters for a configured interface.
- You must globally enable sFlow.
Verify all slots use the default polling-interval configuration.
Switch:1(config-if)#sflow counter-interval 525
Switch:1(config-if)#show sflow interface 1/1-1/10
                         sFlow Port Configuration Info
Port   Packet-Sample-Rate  Max-Header-Size Counter-interval  Collector-list
                                           (in secs)
1/1    0                   128             525               1,2
1/2    0                   128             525               1,2
1/3    0                   128             525               1,2
1/4    0                   128             525               1,2
1/5    0                   128             525               1,2
1/6    0                   128             525               1,2
1/7    0                   128             525               1,2
1/8    0                   128             525               1,2
1/9    0                   128             525               1,2
1/10   0                   128             525               1,2
All 10 out of 10 Total Num of sflow port entries displayed
Use the data in the following table to use the sflow counter-interval and show sflow interface commands.
| Variable | Value |
| <1–3600> | Specifies the polling interval for a slot. Default value is 0 (disabled). |
| {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} | Identifies the
                                    slot and port in one of the following formats:
